Visitor vijayve
Compilation error when using OpenCV library with Vivado HLS
I am trying to run the sample example provided to us by Xilinx which makes use of OpenCV library function calls when run using Vivado HLS 2013.1.
I am following the video posted by Xilinx at
http://www.youtube.com/watch?v=Y2iHh-HtXn4
But when I try to Build the sample design,I get the below errors.
Starting C simulation ...
C:/Xilinx/Vivado_HLS/2013.1/Win_x86/bin/vivado_hls_bin.exe -flow csim -flow_args " -clean -setup"
@I [LIC-101] Checked out feature [VIVADO_HLS]
@I [HLS-10] Running 'C:/Xilinx/Vivado_HLS/2013.1/Win_x86/bin/vivado_hls_bin.exe'
            for user 'xyz' on host 'xyz' (Windows NT_intel version 6.1) on Mon Apr 22 16:20:20 -0700 2013
            in directory 'C:/Users/xyz/test14/solution1'
   Compiling C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp in debug mode
   Compiling C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/top.cpp in debug mode
   Generating csim.exe
C:/Users/xyz/test14/solution1/csim/build/obj/test.o: In function `main':
C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp:49: undefined reference to `cvLoadImage'
C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp:50: undefined reference to `cvGetSize'
C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp:50: undefined reference to `cvCreateImage'
C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp:59: undefined reference to `cvSaveImage'
C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp:61: undefined reference to `opencv_image_filter(_IplImage*, _IplImage*)'
C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp:62: undefined reference to `cvSaveImage'
C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp:64: undefined reference to `cvReleaseImage'
C:/Users/xyz/Documents/xapp1167/xapp1167/sw/demo/test.cpp:65: undefined reference to `cvReleaseImage'
C:/Users/xyz/test14/solution1/csim/build/obj/test.o: In function `Z17IplImage2AXIvideoILi32EEvP9_IplImageRN3hls6streamI7ap_axiuIXT_ELi1ELi1ELi1EEEE':
C:/Xilinx/Vivado_HLS/2013.1/include/hls_opencv.h:129: undefined reference to `cvGet2D'
C:/Users/xyz/test14/solution1/csim/build/obj/test.o: In function `Z17AXIvideo2IplImageILi32EEvRN3hls6streamI7ap_axiuIXT_ELi1ELi1ELi1EEEEP9_IplImage':
C:/Xilinx/Vivado_HLS/2013.1/include/hls_opencv.h:235: undefined reference to `cvSet2D'
collect2: ld returned 1 exit status
make: *** [csim.exe] Error 1
@E [SIM-1] CSim file generation failed: compilation error(s).
@I [LIC-101] Checked in feature [VIVADO_HLS]
What is the reason for this?
Thank you
Re: Compilation error when using OpenCV library with Vivado HLS
1. It looks like you do not have OpenCV library installed or vivado_hls cannot find where it is.
2. To re-run the reference design in Windows, it is recommended to execute the batch file "Video_library_Windows.bat" provided. Note: according to your install directory, it might be necessary to change the line 2 of the batch file to:
set VIVADO_HLS_HOME=C:\Xilinx\Vivado_HLS\2013.1\Win_x86
