Compiling with VIVADO HLS on Ubuntu 64
Hi ,
I am trying out one of the examples for vivado hls for the application note: XAPP1167, and I am getting the following problems
when firing make sim and for the different projects:
  • for sw/fast-corners:
I am getting this: error: no matching function for call to ‘FAST_t_opr(hls::Mat<1080, 1920, 16>&, hls::Mat<1080, 1920, 0>&, int&, bool&, int [16][2])’
I havent edited anything within the code.
  • for sw/erode:
I am getting this :
/usr/bin/ld: cannot find crt1.o: No such file or directory
I tried working around this problem by : sudo cp /usr/lib/x86_64-linux-gnu/crti.o /usr/bin/
Yet, it still reports the same problem.
 I thought of using usr/bin/g++ instead of the one that comes with Vivado_HLS/.../tools/gcc/bin/g++, but that also did not work out.
Any suggestions ? Thanks :) !
I have heard that it can be difficult to get HLS to work on Ubuntu. If you can't run it on one of supported OSes, you may want to give CentOS a try, which tend to have much fewer issues than Ubuntu.
@mesopotamia.scorpio wrote:
Hi ,
  • for sw/erode:
I am getting this :
Cheers,
Jim
To add, the list of supported OSes can be found in Page 12 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug973-vivado-release-notes-install-license.pdf
Debraj
