Complexity limitation of HLS C/C++ simulation
 For algorithm level simulation, it often needs to run a bunch of simulation patterns like training of DNN etc. Are there figure or experience in the complexity limitation of C/C++ simulation Vivado HLS can afford under Linux ?
I just want to have a feeling about the capability and run time of massive C/C++ simulation running under Vivado HLS. Thanks
All the best,
Nan-Sheng
Teacher xilinxacct
Re: Complexity limitation of HLS C/C++ simulation
@nanson
Due to the speed of simulation, you probably don't want to run anything 'massive' through it... Use simulation sufficient to prove out the algorithm/hardware.
Hope that helps
Please mark as solution accepted to close the issue. Kudos also welcomed. :-)
The intention of the question is to have a understanding on the benchmarks of HLS C/C++ simulation you ever conducted for information.
