akboken
Concatenation of multiple variables into one large variable.
Hi All,
I am faced with following task.
I have following array in my HLS code as an output.
ap_uint<4> ArrayA[256];
I want to convert this ArrayAto ap_uint<64> ArrayB[4];
In other words, I want to concatenate 64 elements of ArrayA into 1 element of ArrayB. I am wondering what is the most efficient way of doing this in HLS ?
According to Xilinx documentation, apint_concatenate() does provide concatenation, but it seems this function is only takes 2 clock cycles. I want to do my concatenation in one clock cycle.
I am wondering what is the best way of doing this in HLS ?
hbucher
@akboken
The union idea wont' work. I just tried and there are two problems:
1. The minimum size of a ap_uint<4> is one byte
2. unrestricted unions (unions with non-pod types) are only allowed in c++0x
 Perhaps a better idea would be:
#include "ap_int.h"
#include <stdint.h>
uint32_t example( uint32_t v1, uint32_t v2 )
	struct Nibble2 {
		uint8_t lo :4;
		uint8_t hi :4;
	union {
		Nibble2  ArrayA[4];
		uint32_t ArrayB[1];
	ArrayA[0].lo = v1;
	ArrayA[0].hi = v2;
	ArrayA[1].lo = v1+1;
	ArrayA[1].hi = v2+1;
	ArrayA[2].lo = v1+2;
	ArrayA[2].hi = v2+2;
	ArrayA[3].lo = v1+3;
	ArrayA[3].hi = v2+3;
	return ArrayB[0];
hbucher
@akboken
#include "ap_int.h"
#include <stdint.h>
	struct Nibble2 {
		uint8_t lo :4;
		uint8_t hi :4;
	union {
		Nibble2  ArrayA[4];
		uint32_t ArrayB[1];
	ArrayA[0].lo = v1;
	ArrayA[0].hi = v2;
	return ArrayB[0];
hpoetzl
Voyager
Voyager
Hmm, arriving late ... what's wrong with:
void foo(ap_uint<4> a[64], ap_uint<64> q[4]) {
    #pragma HLS INTERFACE ap_fifo port=a,q
    #pragma HLS INTERFACE ap_ctrl_none port=return
    for (int i=0; i<4; i++) {
        ap_uint<64> temp;
        for (int j=0; j<16; j++) {
            temp(j*4+3, j*4) = a[i*16+j];
        q[i] = temp;
Thanks in advance,
Herbert
-------------- Yes, I do this for fun!
