naz_rb
Const type array in Vivado HLS
Could someone explain how HLS treats arrays that are declared constants? I declare an array as:
const uint8 myArray [100][100] = {....};
and then access the array by element in the loop. According to the UG902  on p.328, such array is implemented as a ROM and consequently I need to partition it to get more reads in the clock cycle. Why would HLS implement this array as a ROM and use resources instead of converting it to ties of VCCs and GNDs? Do I need to explicitly tell HLS to implement it as ties to VCC and GND?
u4223374
Advisor
Advisor
If you're reading constant indices then it will be implemented like that (although HLS will use a ROM and then Vivado's synthesis tool will convert it to a direct tie to 1 or 0). However, if it's accessed in a loop then you need some sort of addressing system so you can select which tie to 0/1 you want to look at. That is a ROM.
u4223374
Advisor
Advisor
