koidis
Control AXI DMA from PL module
Hi I would like to control an AXI DMA module (Receive channel initialization, Sent channel initialization, DMA start etc) from my HLS component instead of the PS I suppose I have to implement an AXI4 Master interface but I can't find a tutorial on how to access specific addresses (control registers) inside the AXI DMA module.
Any Ideas?
muzaffer
It's very easy. All you need is an axi-master which writes to certain offsets. Assuming that this master is the only one controlling the AXI DMA block (ie directly connected to it instead of going through a multimaster interconnect) then you just write to the offsets described in axi dma spec ie the "AXI DMA Register Address map" so if the port which implements axi_master is "uint32* dma_ptr" you just have to say *(dma_ptr + 1) = foo;
to access the MM2S_DMASR register. This assumes you set the C_BASEADDR to zero
muzaffer
koidis
You have been very helpful,
thanks
msbaloglu
Hello, this thread is a very good example for my problem and thank you for your answer muzaffer. However, could you also tell me how can i connect an axi_master to axilite_slave without an interconnect? I have tried to use an axi_protocol_converter but my attempts have failed.
muzaffer
if you're following the suggestion and making a custom axi initiator (ie master, a terminology I'm trying move away from) then the easiest solution is to make an axi-lite initiator. It's very easy to change the code, by removing some features, to move from a full axi-initiator to a lite-initiator. Basically no burst, and a couple of other restrictions which you won't even notice are missing. Find an axi doc online which shows the differences between axi-full & axi-lite and use the latter.
