Anonymous
Not applicable
Convert Decimal to fixed point
I have coefficients to use for filtering and I would like to convert them into fixed point (hoping that it will decrease the implementation resources):
const ap_ufixed<125,1,AP_TRN_ZERO,AP_SAT> H[256] = {
... 0.00000000000000000000091449017339064687, 0.00000000000000000000062116230274780313, 0.00000000000000000000042127263672158805, 0.00000000000000000000028526830531801544, 0.00000000000000000000019287498479639181
Is this an acceptable way to define an array, or I have to explicitly convert the coefficients to fixed point numbers. If conversion is necessary, then how to do that?
jprice
Given that, that should work but you'll find pretty heavy DSP usage though overall less logic resources (I think, I never tried arithmetic with coefficients that large that weren't floating point). Your syntax is correct, I do that with smaller bit widths frequently.
jprice
To answer your actual question, that should work fine. However looking at your bit widths (125) I suspect you'll end up using way more resources than you care to. However looking at your examples I don't know if you need that many bits. I'd normalize your coefficients and try a few different bit widths and pick smaller ones that still perform acceptably. What kind of a filter is this?
Anonymous
Not applicable
@jprice I am trying to implement a bilateral filter. The coefficients that you saw are the smallest five: they are normalized and the range is 10^-22 : 1. I may be able to decrease the precision, but first I want to succeed with full precision.
jprice
Anonymous
Not applicable
Yep, I decreased width from 125 to 24 bit and it has a similar effect. At least, now the implementation fits on the device.
