Observer bva_rzn
Converting two streams into one
With co \ simulation, an error occurs when merging two threads
in one thread
Message in the console HLS (Vivado HLS 2017.1):
ERROR!!! DEADLOCK DETECTED at 26480000 ns! SIMULATION WILL BE STOPPED! //
// Dependence circle 1:
// (1): Process: AXI_stream.AXI_STREAM_OUT_U0
//      Channel: AXI_stream.B1_V_data_V_U, FULL
//      Channel: AXI_stream.B1_V_keep_V_U, FULL
//      Channel: AXI_stream.B1_V_strb_V_U, FULL
//      Channel: AXI_stream.B1_V_user_V_U, FULL
//      Channel: AXI_stream.B1_V_last_V_U, FULL
//      Channel: AXI_stream.B1_V_id_V_U, FULL
//      Channel: AXI_stream.B1_V_dest_V_U, FULL
// (2): Process: AXI_stream.S2S_U0
//      Channel: AXI_stream.B2_V_data_V_U, EMPTY
//      Channel: AXI_stream.B2_V_keep_V_U, EMPTY
//      Channel: AXI_stream.B2_V_strb_V_U, EMPTY
//      Channel: AXI_stream.B2_V_user_V_U, EMPTY
//      Channel: AXI_stream.B2_V_last_V_U, EMPTY
//      Channel: AXI_stream.B2_V_id_V_U, EMPTY
//      Channel: AXI_stream.B2_V_dest_V_U, EMPTY
// Totally 1 circles detected!
Source
void AXI_stream(u256 aIn[],hls::stream<u16stream> &aOut1)
#pragma HLS INTERFACE s_axilite port=return
#pragma HLS INTERFACE axis  port = aOut1
#pragma HLS INTERFACE m_axi depth = 25920 port=aIn offset=slave
#pragma HLS STREAM depth = 1024 variable=aOut1
    hls::stream<u16stream> B1;
    hls::stream<u16stream> B2;
#pragma HLS DATAFLOW
    AXI_STREAM_OUT(aIn,B1,B2);
    S2S(B1,B2,aOut1);
void S2S(hls::stream<u16stream> &inStream1,
         hls::stream<u16stream> &inStream2,
         hls::stream<u16stream> &OutStream)
    static unsigned short Buf1[32][720];
    static unsigned short Buf2[32][720];
    xL:for(int col=0; col<22;col++)
      xL1:for(int i=0; i<32;i++)
       xL11:for(int j=0; j<32; j++){//xL11
       #pragma HLS PIPELINE
            u16stream lap1;
            u16stream lap2;
            inStream1.read(lap1);
            inStream2.read(lap2);
            Buf1[i][j+col*32] = lap1.data;
            Buf2[i][j+col*32] = lap2.data;
       }//xL11
    L12:for(int i=0;i<32;i++){//L12
       xL12:for(int k2=0;k2<720;k2++)
        {//xL12
            u16stream lap;
            lap.data = Buf1[i][k2];
            OutStream.write(lap);
       }//xL12
      }//L12
    L13:for(int i=0;i<32;i++){//L12
       xL13:for(int k2=0;k2<720;k2++)
        {//xL12
            u16stream lap;
            lap.data = Buf2[i][k2];
       }//xL12
      }//L12
With the co\simulation of the next function, the output of the AXI_STREAM_OUT function is correct.
void AXI_stream(u256 aIn[],hls::stream<u16stream> &aOut1,hls::stream<u16stream> &aOut2)
#pragma HLS INTERFACE axis  port = aOut2
#pragma HLS STREAM depth = 1024 variable=aOut2
    AXI_STREAM_OUT(aIn,aOut1,aOut2);
What could be the problem?
Observer bva_rzn
Re: Converting two streams into one
Problem solved
It is necessary to add directives
  #pragma HLS STREAM depth = ..... variable = ......
in function
