wijm02
Correct usage of ap_ctrl_chain to apply backpressure between functions
I am using Vitis 2019.2
I have a top level module that looks like:
MM2S --> fast_function --> slow_function --> S2MM
The fast function has an internal loop that buffers an input image in a sliding window (BRAM) and sends a signal to the slow function as an hls::stream when the sliding window is ready, so that the slow function will run.
The slow_function processes the information in the sliding window and produces output data. While the slow_function is processing the data in the window, I would like the slow_function to backpressure the fast_function to prevent the contents of the window from changing. I tried to use the hls::stream FIFO between the fast and the slow_function to backpressure the fast_function.
Currently what is happening is that fast_function runs to completion before the slow_function even begins (if the FIFO between them is large enough), or the system deadlocks if the FIFO is full. I would like the fast_function to be backpressured if the FIFO between them is full. Is this possible at all?
I understand that the compiler uses ap_ctrl_hs at the block level interface by default to synchronise functions/blocks in dataflow applications. I did try to use the following at the top level to add the ap_continue signal to the functions when they are synthesised:
#pragma HLS INTERFACE ap_ctrl_chain port=return bundle=control
It would appear that I have not used it correctly.
This is a simplified version of the code, where the slow function merely reads the data from the window and streams it out, instead of processing it. If the backpressure works correctly, the img_inp and img_out should be the same. When I combine the fast function and slow function into a single function, it will give the correct output, but I require the two to be decoupled for performance.
#include <ap_int.h>
#include <hls_stream.h>
typedef struct{
	unsigned int h;
	unsigned int w;
	bool kp;
    bool last;
} pixel_t;
const unsigned int PATCHSIZE = 48;
// mat2stream
template <int SRC_T, int ROWS, int COLS, int NPC>
//static
void mat2stream(xf::cv::Mat<SRC_T, ROWS, COLS, NPC> &img, hls::stream<unsigned char> &imgStream, int size) {
#pragma HLS inline off
	img_conv: for (unsigned int k = 0; k < size; k++) { //vertical, rows
	#pragma HLS loop_tripcount min=8192 max=2073600
	#pragma HLS PIPELINE II=1
		unsigned char tmp = img.read(k);
		imgStream.write(tmp);
void fast_function(hls::stream<unsigned char> &blurStream, unsigned char window_[WIDTH][PATCHSIZE+1], hls::stream<pixel_t> &pixelStream, unsigned int IMAGE_HEIGHT, unsigned int IMAGE_WIDTH){
	circ_buffer: for (unsigned int h = 0; h < IMAGE_HEIGHT; h++){
#pragma HLS loop_tripcount max=1080
//	#pragma HLS PIPELINE II=1
		window_wr_: for (unsigned int w = 0; w < IMAGE_WIDTH; w++){
		#pragma HLS loop_tripcount max=1920
			unsigned char tmp_blur;
			blurStream.read(tmp_blur);
			window_[w][h % (PATCHSIZE+1)] = tmp_blur;
			if ((h == IMAGE_HEIGHT - 1) & (w == IMAGE_WIDTH-1) ){
				pixel_t px2;
				px2.last = 1;
				px2.w = w;
				px2.h = h;
				px2.kp = 0;
				pixelStream.write(px2);
			else
				pixel_t px;
				px.w = w;
				px.h = h;
				px.last = 0;
				px.kp = 1;
				pixelStream.write(px);
		} // w
void slow_function(unsigned char window_[WIDTH][PATCHSIZE+1], hls::stream<pixel_t> &pixelStream, xf::cv::Mat<SRC_T, ROWS, COLS, NPC> &dstMat, unsigned int IMAGE_HEIGHT, unsigned int IMAGE_WIDTH){
	comp: while(1){
	#pragma HLS PIPELINE II=2
		pixel_t temp;
		static bool image_end = 0;
    	if (image_end){
    		image_end = 0;
     		break;
		else
			pixelStream.read(temp);
			image_end = temp.last;
			unsigned int h = temp.h;
			unsigned int w = temp.w;
			unsigned char window_rd =  window_[w][h % (PATCHSIZE+1)];
			dstMat.write(w  + h*IMAGE_WIDTH, window_rd);
extern "C" {
void kernel_accel(ap_uint<INPUT_PTR_WIDTH>* img_inp, ap_uint<OUTPUT_PTR_WIDTH>* img_out, int rows, int cols) {
    #pragma HLS INTERFACE m_axi     port=img_inp  offset=slave bundle=gmem1
    #pragma HLS INTERFACE m_axi     port=img_out  offset=slave bundle=gmem2
    #pragma HLS INTERFACE s_axilite port=rows     bundle=control
    #pragma HLS INTERFACE s_axilite port=cols     bundle=control
    #pragma HLS INTERFACE s_axilite port=return   bundle=control
    const int pROWS = HEIGHT;
    const int pCOLS = WIDTH;
    const int pNPC1 = NPIX;
    xf::cv::Mat<IN_T, HEIGHT, WIDTH, NPIX> img_mat(rows, cols);
	#pragma HLS stream variable=img_mat.data depth=16384
    xf::cv::Mat<IN_T, HEIGHT, WIDTH, NPIX> _dst(rows, cols);
	#pragma HLS stream variable=_dst.data depth=16384
    hls::stream<pixel_t> pixel_st;
	//#pragma HLS STREAM variable = pixel_st depth = 2
	#pragma HLS STREAM variable = pixel_st depth = 16384
    hls::stream<unsigned char> img_st;
	#pragma HLS STREAM variable = img_st depth = 16384
    const unsigned int IMAGE_HEIGHT = img_mat.rows;
    const unsigned int IMAGE_WIDTH = img_mat.cols;
    unsigned char window[WIDTH][PATCHSIZE+1];
    #pragma HLS DATAFLOW
    xf::cv::Array2xfMat<INPUT_PTR_WIDTH, IN_T, HEIGHT, WIDTH, NPIX>(img_inp, img_mat);
    mat2stream<IN_T, HEIGHT, WIDTH, NPIX>(img_mat, img_st, IMAGE_HEIGHT*IMAGE_WIDTH);
    fast_function(img_st, window, pixel_st, IMAGE_HEIGHT, IMAGE_WIDTH);
    slow_function<IN_T, HEIGHT, WIDTH, NPIX>(window, pixel_st, _dst, IMAGE_HEIGHT, IMAGE_WIDTH);
    xf::cv::xfMat2Array<OUTPUT_PTR_WIDTH, IN_T, HEIGHT, WIDTH, NPIX>(_dst, img_out);
wijm02
Thanks for all the replies. After further investigation, I have realised that I need to rewrite the code in such a way that I don't have two functions concurrently accessing a single RAM - rather, only a single function can simultaneously perform read/write operations on a single RAM
scampbell
Hello wijm02,
I think what you are describing is the default behavior between functions in a non-dataflow regions. That is, one function will completely process its inputs, and generate all of its outputs, prior to the next function beginning. The DATAFLOW directive is used to specify that you would like function level pipelining. With DATAFLOW, as soon as one function has output data available, the next function can begin processing. Care must be taken to use canonical forms (specific code structures) to ensure this is applied correctly. This is documented here beginning on page (142):
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug902-vivado-high-level-synthesis.pdf#nameddest=xApplyingOptimizationDirectives
DATAFLOW will apply the correct back pressure for the streaming interface in your multi-rate application. However, as you mentioned, you must ensure the FIFO size in between these functions is large enough to store all the data necessary to hold the output data of the fast function before the slow function can process it. This is discussed briefly on page (221) of the UG902 guide.
OK, I hope this helps,
Scott
tedbooth
@wijm02
Could you post your code or a simplified example?  It is much easier for people to offer suggestions.
For streams you should be using the "axis" Interface type on the stream ports.
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
wijm02
Hi Scott,
Thanks for the quick reply. I have used the dataflow pragma, so I think I have made a mistake somewhere else in my code. Perhaps I have not correctly implemented the canonical form?
Marlon
wijm02
Hi Ted,
My understanding was that the "axis" interface can be used on the top level function to communicate with the host program. Is it possible to use them in sub-functions too?
Marlon
scampbell
Hi Marlon,
You can use the hls::stream class to communicate between functions, but not AXIS. On the interface, they can be combined together, but not between the functions. One other thing I see in your code now is that you are using the Vivado HLS video library. This library is no longer supported and has been replaced by the Vitis Vision library located here:
Code: https://github.com/Xilinx/Vitis_Libraries/tree/master/vision
Documentation: https://xilinx.github.io/Vitis_Libraries/vision/2020.1/index.html
There is a migration guide to help in transitioning between them that is located here:
https://xilinx.github.io/Vitis_Libraries/vision/2020.1/overview.html#migrating-hls-video-library-to-vitis-vision
So, given that, I would recommend then that you migrate your code as soon as possible to make sure you can be supported in that design going forward.
Scott
wijm02
Hi Scott,
Thanks for the message.
I am currently using Vitis Vision 2019.2 right now and moving to 2020.1 is definitely something I would like to do sooner rather than later. I am actually planning to move to 2020.1 when the embedded platforms are released
The pixel_t type I used is a struct that I defined myself (I'll add it into the code for clarity, apologies for not including it), so it might look like I am using deprecated library if there was such a type in the previous library. Plus the window too, I manually defined, rather than using predefined window class
typedef struct{
unsigned int h;
unsigned int w;
bool kp;
bool last;
} pixel_t;
I would like to apply video processing functions in the slow_function, though right now, it can't read the window correctly since the fast_function runs to completion before the slow_function begins
wijm02
