meili
Cosim fails to open file (limit on the number of ports in Vivado 2019.2?)
I have attached a very simple test which deliberately yields a lot of RTL ports if the number of entries in the array is large:
void testFunction(int array[entries]) {
#pragma HLS array_partition variable=array complete dim=0
  for (int i = 0; i < entries; i++) {
    array[i] += 1;
Even if it passes csim and synthesises in Vivado 2019.2 (and Vivado 2020.1), I get the following error during cosimulation before it crashes, if my array contains more than 508 entries:
## run all
WARNING: file ../tv/cdatafile/c.testFunction.autotvin_array_508.dat could not be opened
Failed to open file "../tv/cdatafile/c.testFunction.autotvin_array_508.dat"!
ERROR: Simulation using HLS TB failed.
$finish called at time : 110 ns : File "/test/test/solution1/sim/verilog/testFunction.autotb.v" Line 63135
## quit
The file that causes the Warning/Error is generated by the software, but it is completely empty. Note that if I run the same test using Vivado 2019.1, everything works fine, and the c.testFunction.autotvin_array_508_V.dat file now contains:
[[[runtime]]]
[[transaction]] 0
0x0
[[/transaction]]
[[[/runtime]]]
Playing around with my test, I can't seem to go above ~1530 RTL ports in Vivado 2019.2 without getting the same error, which makes me wonder if there is a limit on the number of ports? If not, what is causing this issue and is it supposed to be like this?
meili
Apparently there's a OS limitation of the number of files that can be open at the same time, and for some reason the number of files that are opened have changed between the Vivado HLS versions. To work around the issue, one can simply increase the number of file that can be open at the same time, e.g. in Linux bash
ulimit -Sn <number of open files>
meili
aoifem
Hi @meili
Thanks for sharing your solution here. Would you be able to mark your post as 'accepted solution', so the community can easily find your answer?
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
meili
Sure! Although it doesn't explain why I have to quadruple the number of files that can be open for one of my projects when I switch between Vivado HLS 2019.1 and 2019.2 and later.
aoifem
Hi @meili
This error is due to a limitation of the OS. If a testcase opens a large number of files, it stretches the file I/O limit of the OS, and leaves very little margin to accommodate for any additional file I/O needed by the tools for their own operation (such as opening temporary files, log files etc.).
The exact number of files a tool can open will vary with each version of HLS, as different versions open varying amounts of additional files to operate.  I'm surprised the number of files you can open varies so drastically, but I believe the tool needs additional files to operate.
I've flagged this with development and they are looking into whether they can eventually provide a solution with would work better with this limitation.
Aoife
jamdodot
how about windows 10?  i have this error  in vivado HLS  2016.4   and i need to increase the number of file that can be open at the same time?
