DSPs vs LUT in Vivado HLS
How can I force the use of LUT only and avoid DSPs in Vivado HLS?
Hi @hamoudyounes ,
There is no direct way, but there are some ways to control resources usage.
RESOURCE directive to specify the resource (core) to implement a variable in the RTL. The variable can be any of
the following:
• array
• arithmetic operation
• function argument
Please check page no. 166 of the link for detailed explanation:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug902-vivado-high-level-synthesis.pdf
Raj.
Hi @hamoudyounes ,
the following:
• array
• function argument
Raj.
