haggaie
Disabling 'relax_ii_for_timing' in Vivado 2019.2
When running Vivado HLS I got this in the log:
INFO: [SCHED 204-61] Option 'relax_ii_for_timing' is enabled, will increase II to preserve clock frequency constraints.
I want to disable relax_ii_for_timing then. However, it looks like the default is to enable it, and the flag in config_schedule can also only enable it. Is there no way to disable this setting or am I missing something?
Here's the output of config_schedule -help:
FORMAT
config_schedule [OPTIONS]
-effort (high | *medium* | low)
-enable_dsp_full_reg
-relax_ii_for_timing (default: 1)
-verbose
Haggai
nithink
@haggaie   sorry there was a miss
config_schedule -relax_ii_for_timing=0
Have equal to as well
Nithin
nithink
@haggaie  you can use
config_schedule -relax_ii_for_timing 0
Nithin
haggaie
Thanks, but this results in an error:
ERROR: [HLS 200-101] 'config_schedule': Unknown option '0'.
FORMAT
    -verbose
command 'config_schedule' returned error code
    while executing
"config_schedule -relax_ii_for_timing 0"
nithink
Nithin
haggaie
Thanks, this worked for me.
zhanghaha
我想问一下,config_schedule -relax_ii_for_timing=0这个命令添加在什么地方
haggaie
I've used this option in a tcl script where I launch the HLS synthesis process.
