ali_flt
Do Vivado implementation options overwrite Vitis HLS export options?
I've noticed that there are several options for config_export in vitis hls such as -vivado_optimization_level and -vivado_phys_opt and their default value is set to 0 and none.
So I wanted to know if these default values mean that when this IP Core is used in a vivado project, which of this cases is true: 1. The IP Core is not optimized at all during implementation or 2. when the phys_opt_design option is set in vivado project, this option overwrites the HLS IP Core export parameters and actually does the place and route optimizations.
Many Thanks,
Ali
dsakjl
Hi @ali_flt ,
yes. They influence the commands:
export_design -flow syn
export_design -flow impl
You can check the documentation Vitis HLS ug1399 in section export_design.
Regards.
dsakjl
Hi @ali_flt ,
those options are independent from the usage of the IP in a Vivado project.
They are needed when you want a more accurate information about clock and resource usage, so that the tool uses vivado to synthesize and implement the IP to give you more accurate info.
Regards.
ali_flt
Hey @dsakjl ,
Thanks for your reply. So If I understood your answer correctly, these hls export options are just for reporting purposes and do not affect the implementation results?
dsakjl
Hi @ali_flt ,
Regards.
dsakjl
Hi @ali_flt ,
if the previous post solved your problem, please, mark it as solution to permit others to reach it.
Regards.
