nanson
Does VHLS provide the analysis of power estimation after enabling the adding a clock-enable port ( ap_ce ) to the design ?
Hi, dear elites,
As far as I learn from the UG902, VHLS provides the directive to add a clock-enable port ( ap_ce ) to the design via the option -clock_enable in config_interface.
However, I'd like to inquire if the user adds the option, does VHLS provide the analysis of power estimation after asserting the input as high against low?  Or if the user would like to compare and analyze the effect of the input ce pin, what's your advise to estimate in Xilinx tool ?
All the best,
nupurs
@nanson
Refer this:
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0008-vivado-power-estimation-and-optimization-hub.html
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
nupurs
@nanson
Power analysis can only be done once the IP has been taken to Vivado.
Nupur
nanson
@nupurs
Would you please suggest the related Xilinx document for further study? Thanks
nupurs
@nanson
Refer this:
Nupur
