Does Vivado HLS work in non-project mode?
I saw people said that HLS is based on projects. Is that true? Does that mean we can't use non-project mode in tcl?
Hi @fiedel,
If you are looking to run Vivado_HLS in batch mode then it is possible by using the command vivado_hls -f <file_name>.tcl. Anyhow the TCL script that is being sourced has to contain the commands including creation or opening of a project.
Hi @fiedel,
Thank you.
