@E Simulation failed: SIGSEGV
Hi, I try to declare array like this
int x[25][256000]
and it caused the  @E Simulation failed: SIGSEGV error. it only caused error in c simulation, but I can synthesize it without problem.
Is it possible to declare such big array for simulation? if it is possible, how?
Advisor
Advisor
Luckily this is easy to fix: just declare it static:
static int x[25][256000]
This both fixes the problem and matches HLS behaviour better (in that this will allocate some memory just for that array that remains for as long as the program runs; it won't be deallocated when the function finishes).
Advisor
Advisor
Hi, thank you for the reply. And it does help the simulation, I can simulate it without error now
But, the problem now, I am initializing the x array using another function, and based on my reading, I cannot do that if it is static.
static int x[25][256000];
int i, j;
x[24][1] = 1;
for(i=24; i<=0; i--){
   for(j=1; j<256000; j++){
      x[i][j] = otherfunc();
printf("x[24][1]=%d\n", x[24][1]);
printf("x[24][2]=%d\n", x[24][2]);
this is my code right now
x[24][1]=1
x[24][2]=0
and this is the result. I can initialized x[24][1] but not other elements in the array.
is there any other way? correct me if I'm wrong
thank you
