ERROR: [COSIM 212-5] *** C/RTL co-simulation file generate finished: FAIL
I encounter with this error when i want to run C/RTL Cosimulation. Also, I read everything in this tutorial and applied many change in pointers and float and time seed variables. But, anything didn't change!
I attached my files to this message.
INFO: [COSIM 212-333] Generating C post check test bench ...
INFO: [COSIM 212-12] Generating RTL test bench ...
ERROR: [COSIM 212-5] *** C/RTL co-simulation file generate finished: FAIL ***
11
while executing
"source C:/Users/Mehrshad/Desktop/Vivado-HLS-Workplace/Sobel_Partial_Calculation/solution1/cosim.tcl"
invoked from within
"hls::main C:/Users/Mehrshad/Desktop/Vivado-HLS-Workplace/Sobel_Partial_Calculation/solution1/cosim.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
Finished C/RTL cosimulation.
Do you have any idea about it?
Tnx,
Mehrshadda3036
Re: ERROR: [COSIM 212-5] *** C/RTL co-simulation file generate finished: FAIL
Hi @mehrshadda3036,
Can you please share us the exact file as the content in the image is different from the attached file but has the same function name? Also, please share the test bench file too to reproduce this issue at our end.
Observer adefan
Did you solve the problem? I have the same issue using Vivado HLS 2017.3.
Observer adefan
resloved in this post.
