Newbie avinres
ERROR: [SIM 211-100] CSim failed with errors.
I am trying to implement a histogram equalization, I wrote the code, given in the attachment. The code synthesizes but when I do simulation, it fails with following error. I am not getting what is wrong with my code. Please help.
Starting C simulation ...
/cad/xilinx/Vivado_HLS/2016.4/bin/vivado_hls /home/sanjay-t1/Desktop/Avinash/test/solution1/csim.tcl
INFO: [HLS 200-10] Running '/cad/xilinx/Vivado_HLS/2016.4/bin/unwrapped/lnx64.o/vivado_hls'
INFO: [HLS 200-10] For user 'sanjay-t1' on host 'localhost' (Linux_x86_64 version 2.6.32-696.3.1.el6.x86_64) on Thu Jun 22 17:40:49 IST 2017
INFO: [HLS 200-10] On os "CentOS release 6.9 (Final)"
INFO: [HLS 200-10] In directory '/home/sanjay-t1/Desktop/Avinash'
INFO: [HLS 200-10] Opening project '/home/sanjay-t1/Desktop/Avinash/test'.
INFO: [HLS 200-10] Opening solution '/home/sanjay-t1/Desktop/Avinash/test/solution1'.
INFO: [SYN 201-201] Setting up clock 'default' with a period of 10ns.
INFO: [HLS 200-10] Setting target device to 'xc7z020clg484-1'
INFO: [SIM 211-2] *************** CSIM start ***************
INFO: [SIM 211-4] CSIM will launch GCC as the compiler.
   Compiling ../../../ap_bmp.cpp in debug mode
   Compiling ../../../../../../equalizehistogram/eq_histo_test.cpp in debug mode
   Compiling ../../../../../../equalizehistogram/eq_histo.cpp in debug mode
   Generating csim.exe
In file included from ../../../../../../equalizehistogram/eq_histogram.h:6:0,
                 from ../../../../../../equalizehistogram/eq_histo_test.cpp:50:
../../../../../../equalizehistogram/ap_axi_sdata.h:48:0: warning: "AP_INT_MAX_W" redefined [enabled by default]
/cad/xilinx/Vivado_HLS/2016.4/include/etc/ap_private.h:92:0: note: this is the location of the previous definition
In file included from ../../../../../../equalizehistogram/ap_interfaces.h:50:0,
                 from ../../../../../../equalizehistogram/eq_histogram.h:7,
/cad/xilinx/Vivado_HLS/2016.4/include/ap_stream.h:70:2: warning: #warning AP_STREAM macros are deprecated. Please use hls::stream<> from "hls_stream.h" instead. [-Wcpp]
In file included from ../../../../../../equalizehistogram/eq_histogram.h:7:0,
../../../../../../equalizehistogram/ap_interfaces.h:64:0: warning: "PRAGMA" redefined [enabled by default]
/cad/xilinx/Vivado_HLS/2016.4/include/hls/utils/x_hls_defines.h:49:0: note: this is the location of the previous definition
                 from ../../../../../../equalizehistogram/eq_histo.cpp:1:
@E Simulation failed.
INFO: [SIM 211-3] *************** CSIM finish ***************
4
    while executing
"source /home/sanjay-t1/Desktop/Avinash/test/solution1/csim.tcl"
    invoked from within
"hls::main /home/sanjay-t1/Desktop/Avinash/test/solution1/csim.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
Finished C simulation.
Teacher xilinxacct
Re: ERROR: [SIM 211-100] CSim failed with errors.
@avinres
Here is a stab at the issue... be sure to re-define AP_INT_MAX_W before including the arbitrary precision header file.
Hope that helps
If so, please mark as solution accepted to close the issue... Kudos also welcomed. :-)
