ejcspii
ERROR: [XFORM 203-801]
I'm trying to get the single complex FFT example supplied with HLS to work. I managed to get past the broken tcl script that accompanies it. However, synthesis (of the unmodified, Xilinx-supplied example!) fails as follows under 2017.4:
INFO: [XFORM 203-1101] Packing variable 'in' (src/fft_top.cpp:123) into a 32-bit variable.
INFO: [XFORM 203-1101] Packing variable 'out' (src/fft_top.cpp:124) into a 32-bit variable.
INFO: [XFORM 203-712] Applying dataflow to function 'fft_top' (src/fft_top.cpp:122), detected/extracted 3 process function(s):
     'dummy_proc_fe'
     '_codeRepl__proc'
     'dummy_proc_be'.
INFO: [HLS 200-111] Finished Pre-synthesis Time (s): cpu = 00:00:22 ; elapsed = 00:00:12 . Memory (MB): peak = 489.848 ; gain = 141.785 ; free physical = 24720 ; free virtual = 61404
WARNING: [XFORM 203-631] Renaming function 'hls::fft<config1>' to 'fft<config1>' (/opt/Xilinx/Vivado/2017.4/common/technology/autopilot/hls_fft.h:1490)
ERROR: [XFORM 203-801] Interface mode 'ap_auto' on the actual argument 'fft_status.data.V' (src/fft_top.cpp:136) is incompatible with the mode 'ap_fifo' on the formal argument 'fft_status.data.V' for function '_codeRepl__proc' . Please consider to duplicate the function to avoid mode conflicts.
ERROR: [XFORM 203-801] Interface mode 'ap_auto' on the actual argument 'fft_config.data.V' (src/fft_top.cpp:135) is incompatible with the mode 'ap_fifo' on the formal argument 'fft_config.data.V' for function '_codeRepl__proc' . Please consider to duplicate the function to avoid mode conflicts.
ERROR: [HLS 200-70] Failed building synthesis data model.
Did anyone encounter the same?
BTW the testbench coming with this example needs an overhaul, too. It is mixing C and C++ I/O, to name one issue.
ejcspii
Follow-up: as the rror message suggests,
#pragma HLS INTERFACE ap_fifo port=config solves the problem but I'm still unsure why it arises.
ejcspii
May I ask if there is an official position as to why an "official" example is not working as expected, and what is the best remedy to the problem?
Peter
weixiao
void dummy_proc_fe(
bool direction,
config_t* config,
// cmpxDataIn in[FFT_LENGTH],
float in_re[FFT_LENGTH],
float in_im[FFT_LENGTH],
cmpxDataIn out[FFT_LENGTH])
int i;
#pragma HLS interface ap_fifo port=config
config->setDir(direction);
config->setSch(0x2AB);
for (i=0; i< FFT_LENGTH; i++){
// out[i] = in[i];
out[i].real(in_re[i]);
out[i].imag(in_im[i]);
void dummy_proc_be(
status_t* status_in,
bool* ovflo,
cmpxDataOut in[FFT_LENGTH],
float out_re[FFT_LENGTH],
float out_im[FFT_LENGTH]
/*cmpxDataOut out[FFT_LENGTH]*/)
int i;
#pragma HLS interface ap_fifo port=status_in
// out[i] = in[i];
out_re[i] = in[i].real();
out_im[i] = in[i].imag();
*ovflo = status_in->getOvflo() & 0x1;
You can add the red statements in your void Function
thanks,
Jeff
