ERROR: [XOCC 203-190] Cannot burst array 'feature_or_0.x.V' (....cpp:631): variable is not an array with scalar elements.
I try to burst the read on the port "feature_or_0" , which is an 512 bit width data_packed structure. See the below code.
The software emulation goes well.
But when run the hardware emulaiton compilation, the compiler complained:
ERROR: [XOCC 203-190] Cannot burst array 'feature_or_0.x.V' (/...cpp:631): variable is not an array with scalar elements.
ERROR: [XOCC 200-70] Synthesizability check failed.
ERROR: [XOCC 60-300] Failed to build kernel(ip) pcaf_fpga, see log for details: ../vivado_hls.log
ERROR: [XOCC 60-599] Kernel compilation failed to complete
ERROR: [XOCC 60-592] Failed to finish compilation
../../../utility/rules.mk:126: recipe for target 'xclbin/pcaf_fpga.hw_emu.xilinx_vcu1525_dynamic_5_1.xo' failed
make: *** [xclbin/pcaf_fpga.hw_emu.xilinx_vcu1525_dynamic_5_1.xo] Error 1
typedef struct point_512_64//for or read 64 value for each read
        ap_fixed<8,1> x[512/8]; //8 bit for each value
} D_point_512_64;
extern "C"{
void pcaf_fpga(
              const D_point_512_64  *feature_or_0,//in original feature data
    #pragma HLS INTERFACE m_axi port=feature_or_0  offset=slave bundle=gmem1 max_read_burst_length=16
    #pragma HLS INTERFACE s_axilite port=feature_or_0  bundle=control
#pragma HLS data_pack variable=feature_or_0 ..... }
void read_feature_or(const D_point_512_64 *feature_or,Dtype_uint data_size, Dtype_uint index, Dtype_s *feature_or_buffer){ D_point_512_64 feature_or_temp[16]; #pragma HLS ARRAY_PARTITION variable = feature_or_temp complete dim=0 memcpy(feature_or_temp, &feature_or[index*D_OR/64], 16*sizeof(D_point_512_64));
Please help.
Tags (2)
Teacher xilinxacct
Re: ERROR: [XOCC 203-190] Cannot burst array 'feature_or_0.x.V' (....cpp:631): variable is not an array with scalar elements.
@mathmaxsean
It sound like to me, that the array is made up of non-scalar (simple type; int float, ...) values. Don't use an array with the complex types in this case.
Please mark as solution accepted.
Teacher xilinxacct
@mathmaxsean
