Efficient way of implementing code in hls?
I have two dimensional array S[65][65] of 32 bits size. I need to initialize all elements it with zeros in vivado hls. How do i implement it with less latency.
right now i am following way of coding but it is causing high latency.
for(int i=0;i<65;i++)
for(int j=0;j<65;j++)
SM[i][j]=0;
Re: Efficient way of implementing code in hls?
HI @rocky_149 ,
Have you checked the "Array Initialization" topic at page 315 of UG 902  ?
HI @rocky_149 ,
HI @rocky_149 ,
If your query has been answered or your issue is solved, can you please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply) ?
If the issue is not solved/answered, please reply to this thread giving more information on your current status.
