Observer apitsodani
Error : stopped,reason="end-stepping-range"
I am trying to simulate a big design but got the following error in middle of simulation
@E Simulation failed: SIGSEGV.
@E [SIM-1] CSim failed with errors.
while executing
"csim_design -clean"
To check the problem, I ran the design in "debug" mode, it showed the following output(blue) generated by the command
printf(" %i motion block is %i\n",i,out[i]);
175 motion block is 0  -> Expected
176 motion block *stopped,reason="end-stepping-range". ->Error
What can be the reason for this "end-stepping-range". Can it be memory issue as my design is quite big and computationally intensive?
P.S. -  1) Synthesis of this design completed without any error.
           2) I have tried to re-create the whole design
Observer arpitsodani
Re: Error : stopped,reason="end-stepping-range"
Thanks for your reply,
On investigating more on SIGSEGV error, i found that it mostly occurs due to an array being accessed out of it bounds.
I found the error in my code. And its working now.
Arpit
This could be a memory issue. Would it be possible to run the design in 2014.4 if you are not doing so? If yes then kindly archive the testcase along with Testbench so that I can escalate the matter. SIGSEGV is usually a crash and needs to be investigated further.
Debraj
Arpit
Could you post the resolution here for the benefit of other community members and mark it as an Accepted Solution to close this thread?
Debraj
