abnerlim
Error when apply dataflow directive in Vivado HLS
I applied the dataflow directive to the top module of my design. But it gives me an error:
@E [XFORM-722] Found unsupported dataflow constructs in function : control flows are not allowed outside of loops.
There is no loops in main function, the loops are all in sub-functions and I have unroll them.
Have tried fixing it whole day, still get this error. Anyone know what is the real cause of this error?
Thanks in advance for replying my post.
Abner
duncanm
For dataflow to work, each function or loop needs to be able to have data flow unconditionally into the next. It's likely your design contains control code around the functions or loops, such that some of them are conditionally executed.
  if (some condition)
      function1
   function2
   function3
If these conditions, or control statemens exists, try to push them into the function or loops.
You may also want to file a web case with support that the message should be clearer.
