shahid
Execution time in HLS for an IP
I have generated an IP using Vivado HLS. The execution measured from HLS and the execution time which is measured actually differs significantly. Execution calculated by HLS is very small (0.14 ms) but when i measured it in real scenario using AXI timer it shows 3.20 ms. Why there is so much difference? HLS does not tell about actual execution time?
Waiting for kind reply.
Tags (2)
muzaffer
how much interaction is there between PS & PL for the IP ? Where does the IP get its input?
u4223374
Advisor
Advisor
The obvious reasons are:
(1) It's waiting on I/O. If it's streaming in from an AXI DMA (or out to an AXI DMA) and the DMA pauses, the block will be forced to pause too. Similar problems if it's streaming to/from any other block, or using an AXI master for RAM access, or anything like that.
(2) You've given it incorrect information during synthesis. Almost any block will "complete" (according to HLS) in 100ns if you put "#pragma HLS LOOP_TRIPCOUNT max=1" in the main loop. Of course, if it actually runs 10000000 iterations before reaching a "stop" condition, this number will be completely wrong.
shahid
Hello muzaffer,
Thanks for your reply. PS is connected to the IP through GP0 and IP takes matrix as input.  When i start the execution of IP, i also start the AXI timer which counts the clocks taken by IP to complete execution.
waiting for your kind reply.
shahid
muzaffer
do you count the time of loading data into the IP or do you just start counting when you trigger "start". Also how do you decide when the IP is done? Do you have an interrupt or do you poll the "done" bit?
You should realize that writing through GP0 is extremely slow (20 MB/s max). Make sure that the delay the write is going to introduce is accounted for in your calculations.
shahid
Hello muzaffer,
I start counting when i trigger "start" and then i poll done bit. In this way i am measuring the execution time.
bwaj_ster
How is the execution time measured on HLS ?
