Exporting project with HLS streaming
Accepted Solution Solved
Accepted Solution
Good day!
I want to use streams from hls_stream.h lib. I want to compile my HLS project with testbench using BorlandC or GCC. How can I export streams if I want to use another tool not Vivado HLS. Are there any libs similar to hls_stream.h in standard c++ language libs?
Re: Exporting project with HLS streaming
@slipknotchik hls_stream.h can be used from regular c++ programs with a standard compiler. In fact this is exactly how HLS flow works, ie you run your regular testbench + function to be accelerated in csim first where both pieces go through a regular compiler.
All Replies
