Visitor davidjensen
Floating point multiplier.
Hi HLS users.
I am trying to make a IP core. This is a floating point simple multiplier. I have made it in Vivado HLS 2017.2 and exported it a verilog. Then i added it into Vivado 2017.2 and can see seen as named flotPrototypec_0 in screenshot below.
After adding it and updating the hardware i could see it was added to xparameters.h. But i am unsure how to interact with it. I have used the GPIO before and that worked, well but i can't figure out how to interact with my new ip core.
Any help would be greatly appreciated
This is my ip core
floatPrototype.h
https://pastebin.com/GTrpAU7h?fbclid=IwAR2_Xlzc1OfscwaN6l4XdkHy1_SGkPh78UcfQt0pIG7SsGAsOOXCMirlOgU
floatPrototype.cpp
https://pastebin.com/4x4MC5py?fbclid=IwAR2RnZN00tVhN3-7Ir7l-8gdglvZqmsohveo1TS8n3kvKrkcGju_5lNJA6Y
 EDIT also added the systemC file
https://pastebin.com/XkhJDUAq?fbclid=IwAR2JnMnlBDPw3iFhHboWM5rqw4Dp1Bt6uCIbmVtm66kU5hJ5whdGpRpCMHE
This is the xparameters.h for it
/* Definitions for peripheral FLOATPROTOTYPEC_0 */
#define XPAR_FLOATPROTOTYPEC_0_S_AXI_SLV0_BASEADDR 0x43C00000
#define XPAR_FLOATPROTOTYPEC_0_S_AXI_SLV0_HIGHADDR 0x43C0FFFF
The entire file xparameters. This also have the GPIO that i have working
https://pastebin.com/w8iCCt5u?fbclid=IwAR1kXPWDGz37RcrbsFc71CNLZpbj6sd2l0b1coC_uV25wto5CLLWKzrPOLc
Re: Floating point multiplier.
@davidjensen
Follow steps similar to those given on lab 10 page 240 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug871-vivado-high-level-synthesis-tutorial.pdf
Nupur
