mahkoe
Free running counter in parallel with other logic
In my design, I need to have a free-running counter which ticks every clock cycle.
However, I also need to output this value via an AXI stream protocol every "once in a while". (To be more specific, my design receives commands over an input AXI stream, then depending on the command, will output the current count value on the output AXI stream).
I've looked at a few other posts on the forums, and the only solution I could find was to make sure my design has an II of 1. But even if I do that, the count value only increments between AXI Stream writes. Here is some simplified code that exhibits the problem:
#include <hls_stream.h>
#include <ap_int.h>
void tick(ap_uint<64>& count) {
#pragma HLS PIPELINE II=1
	count++;
void write_time(hls::stream<ap_uint<64> > &out, ap_uint<64> count) {
	out << count;
void ptp(
		hls::stream<ap_uint<64> > &in,
		int *mem
#pragma HLS INTERFACE ap_ctrl_none port=return
#pragma HLS INTERFACE axis register both port=out
#pragma HLS INTERFACE axis register both port=in
	static ap_uint<64> count;
	tick(count);
	write_time(out, count);
And here is a screenshot of the simulation:
u4223374
Advisor
Advisor
This is a fine example of "not a job for HLS". HLS mimics the behaviour of a single-threaded C program. It will perform parallel processing for performance gains, but the behaviour it's aiming for is single-threaded. It follows directly that trying to implement a multi-threaded program is going to go poorly. It's never going to simulate accurately, and could well change behaviour in each new version of HLS.
I would suggest instead having an external timer (just a 64-bit counter), connected to a port on the HLS block that has been declared volatile. This tells HLS that it must perform every read/write as specified - no internal buffering is allowed. It'll still be impossible to simulate, but at least it should work consistently in hardware.
nmoeller
@mahkoe,
I think you need an if statement around the output. The code, the way it is written, is incrementing count and then writing it. The IP can't write out, so it doesn't do anything until it's allowed to write again. You want the code to increment count unconditionally, then output the value when you need it.
Nicholas Moellers
Xilinx Worldwide Technical Support
mahkoe
I am not sure how this solves the problem. Even if I were to gate the outputting statement in an if block, I would still have a problem with the AXI write blocking.
u4223374
Advisor
Advisor
mahkoe
In the end I did separate the counter (as though it were a separate "thread") into a different HLS core. This solved my problem, and it appear to be the "correct" way to do things.
