Generate random Rayleigh Fading channel
Is anyone here can share how to generate random Rayleigh fading channel in a matrix form of  5 x 5?
If I can use H = 1/sqrt(2)*(randn(5,5) + 1i*randn(5,5)) in MATLAB, then, how to write it in C++?
Thank you very much.
Scholar dgisselq
Re: Generate random Rayleigh Fading channel
The easy way?  Random numbers are commonly generated on FPGAs using linear feedback shift registers.  With a long enough register, you can add about 12 results together to get something that looks like a Gaussian.
The hard way?  There are much better ways of generating Gaussian numbers using floating point math.  Feel free to check out Numerical Recipes for some examples.
Dan
Thank you. But from the channel, how we can generate hermitian positive definite matrix, Z=HH^Herm, where H is the random Rayleigh fading channel which is iid and follows CN(0,1) distribution? Do we still need to generate a long register like in linear feedback shift register and do multiplication?
Scholar dgisselq
You might need to explain to me what this matrix H is.  Does it represent a band diagonal system, such as might be created from an FIR filter or something else?
Dan
I tried to generate Rayleigh fading channel that follows normal distribution with zero-mean unit variance. I have tried to generate in in C++ and it worked. However, it did not work in Vivado HLS even though in C Simulation. My code is as below:
header file:
#ifndef _rayleighfadingchannel_H_
#define _rayleighfadingchannel_H_
#include <complex>
#define rows  4
#define cols  8
#define order  4
typedef  std:: complex<float>  cfloat_t;
//Prototype of top level function for C-synthesis
void rayleighfadingchannel(cfloat_t Z[10][10],cfloat_t H[rows][cols]);
#endif //__rayleighfadingchannel_H__ not defined
cpp file:
#include "rayleighfadingchannel_h.h"
//library to generate Rayleigh fading channel
//mt19937 gen((int)time(0));
//normal_distribution<double> dist(0.0, 1.0);
//number of rows and columns
#define rows = 4;
#define cols = 8;
#define order = 4;
int i,j,k;
const double sq = sqrt(2.0);
//Generate Rayleigh fading channel, H
for (int i = 0; i < rows; i++)	{
		for (int j = 0; j < cols; j++) {
			H[i][j] = cfloat_t(dist(gen), dist(gen)) / sq;
//Generate Hermitian positive definite matrix, Z=HH^H
for (int i = 0; i < order; i++)
		for (int j = 0; j < order; j++)
			Z[i][j] = 0.0;
			for (int k = 0; k < cols; k++)
				Z[i][j] += H[i][k] * conj(H[j][k]);
testbench file:
#include <iostream>
#include <complex>
#include <cmath>
int main()
	int i, j, k;
	mt19937 gen(time(0));
	cfloat_t Z[10][10],H[rows][cols];
	//call multiplication function
	rayleighfadingchannel(Z,H);
	//print
	std::cout << "\nChannel matrix, H:" << "\n";
	for (int i = 0; i < rows; ++i)
	    std::cout << "{";
		for (int j = 0; j < cols; ++j)
			std::cout << H[i][j] << ' ';
			if (j == cols - 1)
				std::cout << "}" << std::endl;
			else
				std::cout << ",";
	//print
	std::cout << "\nHermitian matrix, Z:" << "\n";
	for (int i = 0; i < order; ++i)
		std::cout << "{";
		for (int j = 0; j < order; ++j)
			std::cout << Z[i][j] << ' ';
			if (j == order - 1)
			else
				std::cout << ",";
	return 0;
the error that appeared:
Compiling ../../../../rayleighfadingchannel_tb.cpp in debug mode
../../../../rayleighfadingchannel_tb.cpp: In function 'int main()':
../../../../rayleighfadingchannel_tb.cpp:11:2: error: 'mt19937' was not declared in this scope
../../../../rayleighfadingchannel_tb.cpp:11:10: error: expected ';' before 'gen'
../../../../rayleighfadingchannel_tb.cpp:12:2: error: 'normal_distribution' was not declared in this scope
../../../../rayleighfadingchannel_tb.cpp:12:22: error: expected primary-expression before 'double'
../../../../rayleighfadingchannel_tb.cpp:12:22: error: expected ';' before 'double'
make: *** [obj/rayleighfadingchannel_tb.o] Error 1
ERROR: [SIM 211-100] 'csim_design' failed: compilation error(s).
Thanks for any response.
