Generate random number in HLS
Is there any way to generate a (psuedo) random number in HLS.
It would be an option to create an LFSR in VHDL and stream this to the HLS block as an input but requires some more complexity to the design.
Re: Generate random number in HLS
pseudo random number generator in c
Just search for the above phrase in your favorite search engine.
Austin Lesea
Principal Engineer
Xilinx San Jose
@chesh hls takes C as input so you can use a C prng.
try this: http://random.mat.sbg.ac.at/results/karl/server/ for size ;-)
