HLS 2018.3 CSIM is BROKEN on Ubuntu 18.04 LTS
I had this error under 2018.2, but then noticed that 18.04 LTS was only supported on 2018.3, so I uninstalled everything and installed fresh 2018.3.
INFO: [SIM 211-2] *************** CSIM start ***************
INFO: [SIM 211-4] CSIM will launch GCC as the compiler.
ERROR: [SIM 211-100] 'csim_design' failed: compilation error(s).
INFO: [SIM 211-3] *************** CSIM finish ***************
4
    while executing
"source /home/xxxxx/training/hls_tool_flow/lab/zcu102/dct/dct_prj/solution1/csim.tcl"
    invoked from within
"hls::main /home/xxxxx/training/hls_tool_flow/lab/zcu102/dct/dct_prj/solution1/csim.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
Finished C simulation.
Extremely frustrating to have no other debug information to figure out what's wrong. Finishing up day 2 of HLS training and haven't been able to get past Lab 1.
I have seen the same issue with ubuntu 18.4 and Vivado 19.1.
I found this answer:
https://forums.xilinx.com/t5/Design-Entry/Vivado-2018-3-error-launch-hls/td-p/940856
So, after installing build-essential the issue gone.
sudo apt update
sudo apt install build-essential
Best,
Paul
Can confirm, have the same problem on my 18.04 box.
16.04 works fine.
cc@noblis,
I'm not able to repdouce the issue. It's possible it's specific to certain project data? Another possibility could be that the OS is missing some dependency. Could you try the steps in this AR: https://www.xilinx.com/support/answers/66184.html?
Nicholas Moellers
Xilinx Worldwide Technical Support
It's straight-out-of-the-box lab code from the Hardent HLS class, so unlikely to be project data.
ldd-recursive gives:
linux-vdso.so.1
librdi_common.so => not found
libtcmalloc.so.4 => not found
/usr/lib/x86_64-linux-gnu/libstdc++.so.6
/lib/x86_64-linux-gnu/libm.so.6
librdi_commonmain.so => not found
/lib64/ld-linux-x86-64.so.2
/lib/x86_64-linux-gnu/libgcc_s.so.1
libboost_signals.so => not found
/lib/x86_64-linux-gnu/libc.so.6
I installed libboost-signals-dev and that fixed the missing libboost_signals. I also installed libctmalloc-minimal4 and that did *not* fix the missing libtcmalloc.
I can't find any references to librdi_common* anywhere (other than Vivado trouble reports).
I should add, the UI itself runs fine and can synthesize. It's just CSIM that's b0rked.
...do you have a line like:
#include "/opt/Xilinx/Vivado/2018.2/include/gmp.h"
in your header file?
I did and it was pointing to a none existing folder. The result was the errro you saw.
Found it by running make -f csim.mk in solution1/csim/build/csim
Thomas
sudo apt update
Best,
Paul
Hi cc@noblis
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
Thanks. I felt the same frustration that cc@noblis described.
Actually the problem was with the training Lab PDF - instead of a normal "-" char it had a strange hyphen. I was using the exact string with copy&paste and so I would always get an error.
I will try to alert whoever is making the PDFs never to use this character again.
