goldshakil
HLS Array Implementation
I have tried make an IP that does simple multiplication of two numbers and returns the answer as follows:
This one works just fine but my current goal is to extend this so that a,b,answer are arrays.
a ->a[10]
b->b[10]
answer->answer[10]
However, since am not good in HLS envrinoment am not really sure how can I achieve that. I have tried to return a pointer from this function but that doesn't work.
Thank you so much.
wenchen
Hi @goldshakil ,
   Since you are new to HLS, refer to the examples in UG871, UG902 and code examples on HLS home page.
typedef int dina_t;
typedef int dout_t;
typedef int dinb_t;
void array_RAM (dout_t d_o[4], dina_t d_a[4], dinb_t d_b[4]) { int i; For_Loop: for (i=0;i<4;i++) { d_o[i] = d_a[i] * d_b[i]; } }
Wen
**~ Got a minute? Answer our Vitis HLS survey here! ~**
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
wenchen
Hi @goldshakil ,
typedef int dina_t;
typedef int dout_t;
typedef int dinb_t;
Wen
goldshakil
I have followed the tutotrial and wrote the following code:
However, I have no idea how to use the driver functions in SDK to write and read the arrays.
can you please help me out? ( I assume the write words and read words should be used but not sure how)
wenchen
Hi @goldshakil ,
      You can have a carefully look at UG871 page93 && chapter 10 to figure out where the HLS IP driver lies and how to use it on ZYNQ device.
goldshakil
In pages 90-95 after synthesizing there are no functions to set or get the array.
as far it goes for  chapter 10 it handles integers and that works fine for me too, however when I switch to array it doesn't seem to generate any set and get functions(in the drivers).
the functions I get (in the drivers generated) are XXX_Write_XXX_Words and XXX_Read_XXX_Words
I have been trying my best but I can't seem to figure out how to use these functions.
please help me out.
Thank you so much
dishlamian
If your target board has a base Vitis platform available (all Alveo boards, ZCU102/104 and zc702/706), I would recommend using the Vitis accelerator flow. Forget about AXI Lite for your arrays, switch to memory-mapped (m_axi) and convert your array arguments to pointers, and follow this example:
https://github.com/Xilinx/Vitis_Accel_Examples/tree/master/hello_world
In this flow there is no need to spend days tinkering with Xilinx SDK tying to figure out how all the random functions to communicate between the host and the FPGA work.
