Teacher xilinxacct
HLS: C or C++ for new designs?
Reading through the HLS manual, it appears the C++ may be ‘slightly’ better supported (e.g. possible larger limits for arbitrary_precision, less gotchas for casting, better floating point simulation, …)
Are there any cases where the C version can do things that C++ version can’t? (e.g. any downside to using the C++ in HLS?) Any runtime (e.g. final implementation, not compile time) overhead for using C++ or C?
Assuming someone knows both C & C++, would you suggest C++ be used for new designs?
Scholar u4223374
Re: HLS: C or C++ for new designs?
In my opinion, the preferred option is to use C++, but try to keep the code as close to C as is reasonably possible.
The key advantages for C++ in HLS are:
- Fixed-point (not supported in C)
- Arbitrary-precision integers (and fixed-points) can have their length defined by macros.
- Function templates - which are very, very useful when working with arbitrary-precision integers and fixed-point
- Libraries that are only supported in C++ (Streams, Video, etc).
I prefer not to use "full" C++ (primarily creating objects) because I find that HLS doesn't really make good use of them. The big advantage of having a class is that you can just make an object of that type when you need it - but HLS can't because it doesn't support dynamic memory allocation.
With HLS, you implement hardware, don't forget this. HLS is a C-like abstraction that helps writing otherwise complex designs in VHDL or Verilog. HLS deviates from C and C++ in many aspects. And, above all, keep always in mind you are not writing any program in HLS.
If what you like is software, there are lots of processors.
Scholar u4223374
