mikerez
HLS C++ type cast from memory
Hi ALL,
is there any way to cast type from int* (bus or memory interface) to your data struct?
In example:
struct data
   int a;
   char b;
   bool c;
int main( int * memory )
    data cache;
    memcpy((void*)cache,(void*)memory,sizeof(data));
    cache.a=0;
    cache.b=0;
    cache.c=0;
    memcpy((void*)memory,(void*)cache,sizeof(data));
This will give the error "unsupported pointer reinterpretation...".
Is there any way to work with different structures from memory???
Thank you,
mikerez
Got answer from support....
no casting, no C-structures from memory...
