Teacher xilinxacct
HLS COSIM : "Failure: NORMAL EXIT (note: failure is to force the simulator to stop)"
When using the HLS cosimulator in VHDL RTL selection mode... it issue the message.. "Failure: NORMAL EXIT (note: failure is to force the simulator to stop)"
Using Verilog RTL selection mode, it works fine.
1) What is that message trying convey? How to avoid?
2) Is Verilog RTL selection better/preferred or more transparent to the testbench?
Teacher drjohnsmith
Re: HLS COSIM : "Failure: NORMAL EXIT (note: failure is to force the simulator to stop)"
the old VHDL that vivado uses by default, does not have a way to stop a simulation at a certain event, it assumes that all signals stop is the end of simulation.
Verilog does have a way to stop on an event.
the "get around" in the old vhdl was to cause a faliure,
which stops the simulator, but a bit abruptly with lots of warnigns as you have seen, it prints "Failure:"
The answer to that was to add the text to the output "Normal exit",
so on a good exit you see "Failure : Normal exit" , as you do,,,
A pain I know , but quiet all right.
Teacher drjohnsmith
