wijm02
HLS Code Coverage in Vitis 2020.1
Hi all,
I am looking into doing code coverage testing on a design that I have implemented.
What I found so far that under the GCC Host Compiler settings in Vitis, I can select the "Generate gcov information (-ftest-coverage -fprofile-arcs)" under the "Debugging" section, and I can include gcov in the GCC Host Linker Libraries.
When I do this, I am able to obtain code coverage data for the host program when running in SW Emulation.
What I wonder is whether there is a similar method to obtain code coverage of the Kernel.
Marlon
sebo
Voyager
Voyager
Hi @wijm02
I guess there is no such thing available right now.
The only thing I've found is the possibility to use the coverage feature in cosim_design using VCS simulator.
--Sebastien
maps-mpls
Mentor
Mentor
I have not done this, but take a look at:  https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/cosimulationinvitishls.html
You will need a third party simulator that supports code coverage.  I do not believe Vivado's simulator supports this, short of setting a breakpoint on every line, and clearing them as you run t he simulation, and when the simulation is complete, seeing if any breakpoints still exist.
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
sebo
Voyager
Voyager
Hi @maps-mpls
At cosim_design stage, according U1399, code coverage can be obtained using third party simulator VCS. As I use modelsim, I wonder if anyone solved this ?
--Sebastien
