[HLS] How to create assertions for Synthesis
Hi all,
I was wondering how can I create an assertion for synthesis in HLS. So far I've been able to create them for csim, however it's ignored in synthesis.
I guess is based in the fact that you should run your csim prior synthesizing, but I would like to know if there is any option to imply these checks for synthesis as well. In my project, I generate the HLS IP Core based on scripting, and some internal numerical approximations are only valid for specific values of #defines in a header file. I would like to check if those have been changed without requiring a new long simulation.
This is how I'm implementing them so far for CSIM:
assert (INP_ROWS==1072 && INP_COLS==1928); // IMP_ROWS, INP_COLS are #defines in .h
Any ideas? If so, is there any way to throw an error message on them?
Thanks in advance!
PS: I'm, using Vivado HLS 2019.1.
Instructor
Instructor
@domitilo
If you are only trying to validate constant values from a configuration header file, then yes... you may be in luck... using the preprocessor you can test the values of the defines, then use #error to abort the compilation/synthesis.
e.g.
#if INP_ROWS!=1072
#error "some message"
#endif
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed.
Instructor
Instructor
@domitilo
In the synthesized hardware, you would not 'throw an error' per se... but if you want to generate some monitor/debug in the hardware itself, you could generate an 'output'  that is triggered when a condition is true or false... giving you the ability to see what is happening on your synthesized hardware.
Hope that Helps
Thanks for answering.
Sorry, probably I didn't explain myself properly, what I meant is if there is any way to make these check on synthesis time, but not to be implemented in hardware.
Just the way that if INP_ROWS != 1072 the synthesis tool throws an error and stop synthesis, as it does the simulation tool when doing the assert.
I would like to implement these kind of checks to avoid misconfigurations due to wrong values in .h file.
Thanks in advance and sorry for my first explanation.
Instructor
Instructor
@domitilo
e.g.
#if INP_ROWS!=1072
#endif
Hope that Helps
Thanks!, that's what I was looking for, it works perfectly.
