Teacher xilinxacct
HLS Optimization Challenge
I propose a simple challenge. Since people are busy, I suggest we start with a trivial problem that can be implemented in minutes and is well understood by all. To speed things up, I will supply the testbench.
The challenge will be to create the fastest implementation of a string length function.
You may optimize the solution by using any pragma(s) you choose, and implement the function in any way you choose that satisfies the constraints.
The problem will be constrained in the following ways…
1) The prototype of the function shall be … short my_strlen(char str[32]);
2) The solution will be timed against the target device: xczu3eg-sbva484-1-e using the Verilog co-simulation times using Vivado HLS 2018.3.
3) The solution must pass Verilog co-simulation using the provided testbench (but not limiting the character set, to the specific cases in the test set; e.g. you are not allowed to tune the solution to consider the specific character sequences in the testbench. A true solution will allow any/all permutations of the 32 character input sequence)
4) If there is no ‘\0’ character within the buffer, the result shall be 32
The winner be the solution with the fastest timing. If there is a tie with the fastest time, the smaller utilization will be considered the winner. If that also results in a tie, the earliest submission will be deemed the winner.
As part of the goal, is to see alternate solutions, even if your submission is not the best, a Kudo will be awarded by me for novelty (e.g. you are using pragma not used yet, or an algorithm not yet seen.) Of course, I would like to ‘win’ :-), but learning another alternative is also valuable to me.
Of course the submission that wins, will be awarded as solution accepted by me (and if others want to passively play along, and reward the participants/winner, they can ‘subscribe’ to the post (see the ‘subscribe’ option in the menu marked by the 3 dots at the upper right corner of this post.) and once a solution has been marked as accepted, they can give a Kudo as they see fit.
Good Luck (or shall I say Good Skill)
----- TEST BENCH BELOW ---
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
extern short my_strlen(char s[32]);
const char *testCase[] = {
		"1",
		"12",
		"123",
		"1234",
		"12345",
		"123456",
		"1234567",
		"12345678",
		"123456789",
		"1234567890",
		"12345678901",
		"123456789012",
		"1234567890123",
		"12345678901234",
		"123456789012345",
		"1234567890123456",
		"12345678901234567",
		"123456789012345678",
		"1234567890123456789",
		"12345678901234567890",
		"123456789012345678901",
		"1234567890123456789012",
		"12345678901234567890123",
		"123456789012345678901234",
		"1234567890123456789012345",
		"12345678901234567890123456",
		"123456789012345678901234567",
		"1234567890123456789012345678",
		"12345678901234567890123456789",
		"123456789012345678901234567890",
		"1234567890123456789012345678901",
		"12345678901234567890123456789012",
		NULL
int main() {
	char str[33];
	int ret = 0;
	for(int i=0; testCase[i]; i++) {
		strcpy(str, testCase[i]);
		short len = my_strlen(str);
		if (len != (short)strlen(str)) {
			printf("len(%hd) != strlen=%hd\n", len, strlen(str));
			ret = -1;
	exit(ret);
Teacher xilinxacct
Re: HLS Optimization Challenge
Let me seed the pool, just to get things started... (not the best)
short my_strlen(char s[32]) {
#pragma HLS array_partition variable=s cyclic factor=32
#pragma HLS interface ap_memory port=s
	for(short i=0; i<32; i++) {
#pragma HLS unroll
		if (!s[i]) {
			return i;
	return 32;
Teacher xilinxacct
#pragma HLS unroll
		if (!s[i]) {
			return i;
	return 32;
Teacher xilinxacct
Although the solution is not the best, I will accept it... Thanks for those who commented... some saying the challenge was not complex enoiugh to give a lot of variety in results, and others that said my seed response made it too hard to improve upon easily.
When/if I do another challenge in the future. I will make it a bit harder, and not post the long hanging fruit solution. :-)
