HLS RTL Cosimulation stripping last newline from out.gold.dat
I am trying to get a pass indication on validation with my out.gold.dat.
C simulation works fine and passes.
1st result of RTL co-simulation passes.
Then the next result fails with a message:
"\ No newline at end of file"
Then I look at outgold.dat (there are 2 of them), and both have the last newline stripped off.
I can replace the newline(S), but the co-simulation will strip them off again.
What is going on?
Emmett
Teacher xilinxacct
Re: HLS RTL Cosimulation stripping last newline from out.gold.dat
@emmettbradford
I notice you have 2 files names out.gold.dat and outgold.dat. (are you editing one, and comparing another?)
I would not expect the any 'gold' file to be written to in a test bench... only diffed against.
When you 'write' your test output, do you put an newline on the last print? If not, maybe diff is complaining about that (and not the gold file).
Hope that helps. If so, please mark as solution accepted. Kudos also welcomed. :-)
