HLS comprehensive problem
When I wrote the template matching code with vivado hls, it was verified that C simulation could pass, but in the C synthesis report, the clock seemed to be having problems. I think there may be a comprehensive optimization problems, who can help me?
C synthesis report as shown below, the code in the annex.
Re: HLS comprehensive problem
@zz110
If you slow your clock does your design work? (e.g. give it more time to do the work in between)
If so, not 'clock' issue per se.
