HLS : create several clock
I am designing video processing algorithm with vivado HLS.
I wanted to know if it is possible to create several clocks, i mean if the algorithm clock can be different from the AXI clock ?
Also how to do it because i did not found it in the documentation.
Ugo
Multiple clocks are only supported in SystemC designs.  Each SC_MODULE is synthesized using a single clock.
If you are using SystemC, you should be able to know how to do it.
brucey
Just wanted to add to Bruce's reply: we include a SystemC multi-clock example in Vivado HLS installation. It is in the directory below:
C:\Xilinx\Vivado_HLS\2013.2\examples\coding\sc_multi_clock
Cheers,
Jim
