HLS dataflow in a loop iteration
Hi, I have a problem now, I want to parallel the memcpy function and loopj. But cann't use #pragma AP dataflow in a for loop. How can I do this? int buf1[128],buf2[128]; for(i=0;i<100;i++) { memcpy(buf1,in,128*sizeof(int)); for(j=0;j<128;j++){ buf2[j]=buf1[j]+1; } memcpy(out,buf2,128*sizeof(int)); }
Using DATAFLOW is the ideal approach. Once you do that you can check that the Initiation Interval would be less than the latency and you can start to feed new data early. Whats the reason you cant use DATAFLOW?
Debraj
void run(int *in,int *out)
	for(k=0;k<100;k++)
		#pragma AP dataflow
		for(i=0;i<128;i++){
			buf2[i]=buf1[i]+1;
like the code above, when I insert the pragma , the error is: cannot apply dataflow inside a loop that has exit condition.WHY?
How can I using dataflow in a loop?
Thanks!
Use it as:
#pragma HLS DATAFLOW
for(k=0;k<100;k++)
#pragma HLS PIPELINE rewind
for(i=0;i<128;i++){
buf2[i]=buf1[i]+1;
Debraj
Thank you very much! It did work on this example.
But in my real program, there are two loop iteration ouside these three function, and the result is :Unable to satisfy pipeline directive: Loop contains subloop(s) not being unrolled or flattened.
I guess the memcpy function is unable to be pipelined?
I am wondering is there any way that I can pipeline these there function and ignore external for loop?
Thanks!
DATAFLOW is used at function level to enable concurrency of subfunctions or loops within the top function. You can't use it in a loop if that is what you are asking. PIPELINE directive is what you need. memcpy() can be pipelined in 2013.3
	for(k=0;k<100;k++)
		#pragma AP dataflow
		for(i=0;i<128;i++){
			buf2[i]=buf1[i]+1;
Thanks!
Cheers,
Jim
