Visitor gordienkoa1
HLS-internal AXIS Fifo
Hello! I have a question about the implementation of the FIFO module in Vivado hls I read the document UG902 but could not find the answer there. I need to implement a fifo module with a buffer size of 42,000. I can not figure out how to do this in HLS.
static void FifoBuffer(AXI_STREAM &src, AXI_STREAM &dst)
    AXI_STREAM internal_stream;
	#pragma HLS STREAM variable= internal_stream depth= 42000
	  for (int i = 0; i <42000; i ++) {
	#pragma HLS PIPELINE
	        AXI_VALUE in_value = src.read();
	        AXI_VALUE out_value = in_value;
	        internal_stream.write(out_value);
void FifoSplitter(hls::stream<AXI_VALUE> &src, hls::stream<AXI_VALUE> &dst)
#pragma HLS INTERFACE axis port=&src
#pragma HLS INTERFACE axis port=&dst
#pragma HLS DATAFLOW
    FifoBuffer(src, dst);
This is about how I understand how it should be, but I can not synthesize normally, I ask for help.
Tags (2)
Visitor gordienkoa1
Re: HLS-internal AXIS Fifo
I found a solution! I used a full and empty variable of type axi stream. This solution synthesizes a fifo that does not block the exchange while it is not full:
	static AXI_STREAM_DATA temp;
	AXI_VALUE tmp,tmp2;
	#pragma HLS STREAM variable=temp depth=42000 dim=1
	#pragma HLS data_pack variable=temp
	while (!temp.full())
		  tmp.data = src.read().data;
		  temp << tmp.data;
	while (!temp.empty())
		  tmp2.data = temp.read();
		  dst << tmp2;
Visitor gordienkoa1
	AXI_VALUE tmp,tmp2;
		  temp << tmp.data;
		  dst << tmp2;
