benedetto73
HLS manual synchronization & protocol fixed: documentation and resources
I am currently facing a design where a single loop isn't fast enough, and DATAFLOW doesn't work because of the complexity and the feedback among processes.
While experimenting with manual concurrency, I realized that there's very little info about this stuff and protocol fixed directive.
Do you know where to find info about this?
Tags (3)
wenchen
HI @benedetto73 ,
      What information are you currently referring to? UG902 or some other XAPP notes?
      The description about the problems facing in your design are not clear enough. Any logs or code?
Wen
**~ Got a minute? Answer our Vitis HLS survey here! ~**
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
benedetto73
Hi Wen.
In this post I am asking for generic info and documentation. I would like to learn this programming style.
The specific problem is explained in this post.
