HLS module iteration number
Dear,
I have a project require to call many times of hls::Dilate function for small gray 128x128 size picture.  Below for example:
hls::Dilate<hls::MORPH_RECT, iteration>(img_Y1, img_Y2, kernel3x3);
If I make the parameter of "iteration" to be 1, 2...5 are all properly, but the HLS compiler will failed when I set the "iteration" to be more than 100 or 1000...., why?
Note:My project setting is for Zynq AX7045.
nupurs
p.ching.kuang@gmail.com
Does it pass with any higher end device?
Does it fail C-simulation or C-synthesis?
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
nupurs
Nupur
