cerilet
HLS resources and latency increase without any sense
I am coding a program using double-precision floating-point variables to be implemented in a Zynq. I have resource problems and I am trying to shrink it in order to make it fit in the fabric (precision reduction is not a solution).
The algorithm calculates a Tustin discretization of a doubly-fed induction generator (DFIG), which includes among other operations one 4x4 matrix inversion and two 4x4 matrix multiplications.
I have tested two different 4x4 matrix multiplications in a separate project and the latency, initiation interval and resources usage are the following:
Implementation A:
Latency = 60
Initiation Interval = 61
BRAM = 0 (0% of resources)
DSP48E = 28 (12% of resources)
FF = 2664 (4% of resources)
LUT = 4261 (8% of resources)
Implementation B:
Latency = 80
Initiation Interval = 81
BRAM = 2 (1% of resources)
DSP48E = 14 (6% of resources)
FF = 1151 (1% of resources)
LUT = 1984 (4% of resources)
Then, I just use these matrix multiplications as functions in the whole algorithm.
Regarding the whole program, the resources used using either matrix multiplication version A and B are the following:
Using matrix multiplication version A:
Latency = 382
Initiation Interval = 383
BRAM = 16 (5% of resources)
DSP48E = 300 (136% of resources)
FF = 27279 (25% of resources)
LUT = 43124 (81 % of resources)
Using matrix multiplication version B:
Latency = 391
Initiation Interval = 392
BRAM = 20 (7% of resources)
DSP48E = 314 (142% of resources)
FF = 25100 (23% of resources)
LUT = 41491 (77 % of resources)
It doesn't make much sense, does it? Can somebody tell me why is this happening or how can I reduce the number of DSPs used?
Many thanks,
Cerilet
Tags (3)
debrajr
Few quick suggestions to try would be:
a_ Use #pragma HLS INLINE on the matrix-multiplication function in your complete project
b_ Use the ALLOCATION directive on the matrix-multiplication function to limit the number of multiplication operations inorder to encourage Resource sharing. These mul operations usually gets fitted in the DSP.
c_ Use a higher order of binding by setting the config_bind in Solution Configurations
Debraj
