HLS simulation
hi ,
i am using HLS-vivado for the first time.i have done the synthesis and i want to check the ouput waveforms in modelsim for vhdl.the tool has generated some scripts in vhdl folder.i am facing problem in running the scripts.i dont know how to run scripts and where to run.i tried in vivado2012.4 command prompt cosim_design but it is saying the command has not been recognised.pl someone help me in running the scripts
Re: HLS simulation
Try below:
1. In the Co-simulation window, select the RTL language desired as below.
3)      Now a set of files will be generated in your project directory /solution1/sim/Verilog
4)      A script will be generated in language folder (vhdl/verilog) folder with the name cosim.modelsim.scr
5)      Open ISE 14.X command prompt (start --> ISE Design Tools --> ISE Design suite 14.X --> Accesories --> 64 bit command prompt)
6) Type the below command after migrating to the project directory containing cosim.modelsim.scr file using cd
 vsim -gui -do cosim.modelsim.scr.
7) Now the Modelsim window shows up with simulation results.
deepika.
Deepika.
Re: HLS simulation
Did you check this http://www.xilinx.com/support/answers/46243.html ?
Deepika.
Deepika.
Re: HLS simulation
thanks for ur reply.
ya i checked it and from that only i came to know about the scripts and all.
my prob is" To run simulation with Modelsim, source run_modelsim.sh file."
how to do this in hls command prompt?
i need to run the scripts tat are generated but how can i do that?i am not finding any video or ppt to do that.can u pl tell me the steps how to do that
Re: HLS simulation
Did you try opening modelsim and then sourcing the generated .sh file in the transcript window?
Deepika.
Deepika.
Re: HLS simulation
yes but still it is nt working.may be i made a mistake in running the script.
can u pl tell me completely
Re: HLS simulation
Try below:
deepika.
Deepika.
Re: HLS simulation
hi deepika,
thank u so much.i tried as per ur inputs but still a prob occurred.
am attaching u the stuff which i did.the red coloured underline shows the error.
for checking purpose i have double clicked on the cosim.modelsim.it displayed an error.that also i attached /pl go through and reply.
one more dobt which i have is we are c test bench for simulation.output in the console is shown.but same output if i haave to see in modelsim in which i can see and the how long the  simulation runs?
waiting for ur reply
ri**bleep**a
Re: HLS simulation
Did you compile libraries for modelsim using COMPXLIB tool?
Looks like you have not compiled the libraries.
Deepika.
Deepika.
Re: HLS simulation
no.
after running simulation so many outputs ll be coming in that which is the desired output how can i find?
Re: HLS simulation
If you want to use modelsim for simulation, you need to compile the libraries for this tool using COMPXLIB. Refer to this article for the details http://www.xilinx.com/support/answers/33715.htm
Deepika.
Deepika.
