HLS tutorial UG871 (v2016.4) ch10 lab2 problem
Hi, I'm following the vivado HLS  2016.4 tutorial UG871 and downloaded files for ch10 lab2:
Streaming Data Between the Zynq CPU and HLS Accelerator Blocks
without chaning any code and procedure( use as it is).
When run vivado_hls -f run_hls.tcl, I got error message like:
 INFO: [HLS 200-111] Finished Pre-synthesis Time (s): cpu = 00:00:23 ; elapsed = 00:02:55 . Memory (MB): peak = 602.367 ; gain = 553.039
WARNING: [XFORM 203-631] Renaming function 'Loop_realfft_be_stream_output_proc' (./xfft2real.h:121:37) into Loop_realfft_be_stre.
WARNING: [XFORM 203-631] Renaming function 'Loop_realfft_be_rev_real_hi_proc' (./xfft2real.h:116:37) into Loop_realfft_be_rev_.
WARNING: [XFORM 203-631] Renaming function 'Loop_realfft_be_descramble_proc' (./xfft2real.h:88:37) into Loop_realfft_be_desc.
WARNING: [XFORM 203-631] Renaming function 'Loop_realfft_be_buffer_proc' (./xfft2real.h:64) into Loop_realfft_be_buff.
ERROR: [XFORM 203-801] Interface write on 'dout.V.data' has incompatible types. Possible cause(s): data pack is only applied on source(variable) or destination(port).
ERROR: [HLS 200-70] Failed building synthesis data model.
command 'ap_source' returned error code
while executing
"source [lindex $::argv 1] "
Any update to the example code/procesure (seen most examples using older version of vivado hls)? Has anyone seen the same issue, any workaround?
removing the DATA_PACK pragma resolves the problem: as mentioned in some threads, the HLS seemly auto packed AXI-stream struct/parameters; just curious how it worked in older version demo/tutorial.
Hi @jinming_ge,
You can try this:
- Visit this webpage.
- Click on "See all versions" below UG871 description.
- Download the reference files associated with latest Vivado and check if the particular file helps.
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
I'm using UG871 - Vivado Design Suite Tutorial: High-Level Synthesis ( ver2016.4, 11353 KB ) [PDF] and Associated File(s)
Are you suggesting newer version?
The problem can be reproduced with 2017.1 version (same version of Vivado Design Suite and UG871 Associated Files)
