HLS use UltraRam for fifo in dataflow region
I have an HLS module that requires large FIFOs inside an dataflow region. I used hls::stream. For these i want HLS to use UltraRam, but i could not find a way how to tell HLS to biuld the FIFOs with ultra ram.
The Resource pragma only allows FIFO, FIFO_LUTRAM, FIFO_BRAM and FIFO_SRL. I could think of splitting the module in two and put normal fifo ip's in between, but that is not really the preferred way. Is there a way to use ultraram in hls::stream fifos?
Re: HLS use UltraRam for fifo in dataflow region
@emc_three The fundamental problem is that, unlike BRAM, UltraRAM doesn't include FIFO hardware. Using it as a FIFO would require separate hardware implemented in LUTs, and it appears that neither HLS nor the Vivado FIFO generator knows how to do this.
you are right, but the ip "Axis data fifo" does build that additional logic.
