HLS warning during synthesis
I can't solve this warning in synthesis please what's warning mean and how to solve it.
Found false inter dependency for variable 'lineBuff.val[0]' (Encoder_network/Max_Pooling_2.cpp:6)
this is photo for my code without comments
Hi @MGaber123
Would you be able to share a testcase that the community can run? What version of HLS are you using?
Am I correct in thinking that you are using <hls_video.h> ?
If so, this library has been deprecated. Please see the link below for more details. It could be the source of the error.
https://www.xilinx.com/support/answers/75345.html
Aoife
Thanks for your kind response,
I am using version Vivado HLS 2018.3.I am using a video library <hls_video.h> . This library doesn't cause any errors in C simulation but gives me warnings in synthesis.
