MGaber123
Hls warning synthesis
I get this warning please any hint to solve this problem
WARNING: [XFORM 203-713] All the elements of global array 'lineBuff.val[0]' should be updated in process function 'doImgProc244_Loop_2_proc78', otherwise it may not be synthesized correctly
// Defining the line buffer and setting the inter dependency to false through pragmas
hls::LineBuffer<KERNEL_DIM1_2,IMG_HEIGHT_OR_ROWS_PADDING_2,float24_t> lineBuff[CHANNEL_SIZE_2];
hls::Window< KERNEL_DIM1_2,KERNEL_DIM1_2, float24_t> window [BATCH_SIZE_2][CHANNEL_SIZE_2];
//hls::stream<float24_t> inStream2;
// Index used to keep track of row,col
int idxCol = 0;
int idxRow = 0;
int pixConvolved = 0;
//float24_t dataOut[IMG_WIDTH_OR_COLS*IMG_HEIGHT_OR_ROWS]={0};
float24_t currPixel;
float24_t val ;
float24_t valOutput;
float24_t pixelIn=0;
float24_t temp_val=0;
for (int idxPixel = 0; idxPixel < (IMG_HEIGHT_OR_ROWS_PADDING_2*IMG_HEIGHT_OR_ROWS_PADDING_2); idxPixel++)
for(int i=0;i<CHANNEL_SIZE_2;i++)
{ currPixel = outputStream1.read();
lineBuff[i].shift_up(idxCol);
lineBuff[i].insert_top(currPixel,idxCol);
for (int j=0;j<BATCH_SIZE_2;j++)
// #pragma HLS PIPELINE
valOutput=0;
for (int i=0;i<CHANNEL_SIZE_2;i++)
//#pragma HLS UNROLL
for (int idxWinRow = 0; idxWinRow < KERNEL_DIM1_2; idxWinRow++)
for (int idxWinCol = 0; idxWinCol < KERNEL_DIM1_2; idxWinCol++)
temp_val = (float24_t)lineBuff[i].getval(idxWinRow,idxWinCol+pixConvolved);
val = (float24_t)kernel[j][i][(idxWinRow*KERNEL_DIM1_2) + idxWinCol ] * temp_val;
window[j][i].insert(val,idxWinRow,idxWinCol);
this part of my code that i used line buffer
aoifem
Hi @MGaber123
This seems to be a similar issue to your other post:
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/HLS-warning-during-synthesis/td-p/1174710
Could you try updating the library as I suggested in your other post, and let me know if it solves the issue.
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
